Wizfi210 connect
RE: Wizfi210 connect
by kaizen ·
Hi
I don’t understand about your environment.
How to connect between WizFi210#2 and PC. Is it TCP?
Or else, is it connected between MCU#2 and PC using Serial Interface?
In other word, Do you want to use case 1 or case 2 or another case?
by wtx ·
Thank you for your reply!
I want to choose case1.Selecting TCP,wizfi210#1 can send datato wizfi210#2,wizfi210#2 can send data to PC.But wizfi210#2 can’t send data to wifiz210#1 or wizfi210#1 can’t receive data from wizfi210#2.
These are wizfi210#2 setting
at+wd、
at+wm=1、
at+wauth=1,
wizfi210、
at+ndhcp=0、
at+nset=192.168.1.105,255.255.255.0,192.168.1.1、
at+wa=wizfi210,8
at+nctcp=192.168.1.101,5000、
at+nstcp=5000、
at+cid=?
ata2
These are wizfi210#1 setting
at+wd、
at+wm=1、
at+ndhcp=0、
at+nset=192.168.1.101,255.255.255.0,192.168.1.1
at+wa=wizfi210,8
at+nstcp=5000
ata2
by ssekim ·
Hello wtx
I just tested it and succeeded, Please try it again as below.
<#1>
at+wd
[OK]
at+wm=1
[OK]
at+ndhcp=0
[OK]
at+wauth=0
[OK]
[OK]
at+wa=wizfi210,8
IP SubNet Gateway
192.168.1.101: 255.255.255.0: 192.168.1.1
[OK]
at+nauto=1,1,5000
[OK]
ata2
[OK]
<#2>
at+wd
[OK]
at+wm=1
[OK]
at+ndhcp=0
[OK]
at+wauth=0
[OK]
at+nset=192.168.1.102,255.255.255.0,192.168.1.1
[OK]
at+wa=wizfi210,8
IP SubNet Gateway
192.168.1.102: 255.255.255.0: 192.168.1.1
[OK]
at+nauto=0,1,192.168.1.101,5000
[OK]
ata2
[OK]
by danil ·
Hi Wtx,
I want ask you about how can you complete send data from MTU to Wizfi? did your system connecting like this picture http://postimg.org/image/943kqka2r/?
by kaizen ·
Hi
Yes, You’re right. Maybe, wtx also connect like you.
