Ethernet W5500 is not working
- Arduino IDE
RE: Ethernet W5500 is not working
by TheoIm WIZnet ·
SPI communication working normally does not guarantee that network communication is functioning.
WIZnet chips separate the SPI interface and the PHY (Ethernet physical layer), so if the PHY is not operating properly, all network functions such as DHCP and ping will fail.
In your current situation:
→ It is appropriate to first suspect an issue at the PHY level.
In particular, LEDs not responding at all usually indicates not a software issue, but that the physical link itself is not being established.
If you could share how the board was designed, I can provide more specific guidance.
RE: RE: Ethernet W5500 is not working
by nbabu0001 ·
https://cdck-file-uploads-europe1.s3.dualstack.eu-west-1.amazonaws.com/arduino/original/4X/8/5/3/8534addb10eaf95ae5df84cf872b99a9925fbf75.pdf Here is the link of schematic , Please let me know if you have any issues opening this.Below is the code i used tfor testing:-
Here is the output for the code below:-
12:53:39.781 -> PHYCFGR: 0xBA
12:53:39.781 -> Link: DOWN
12:53:39.823 -> Speed: 100 Mbps
12:53:39.823 -> Duplex: Half
