W5500 executing your Ethernet code for DHCP - Why delay required
- W5500
RE: W5500 executing your Ethernet code for DHCP - Why delay required
by WIZnet AI AI generated ·
by Grace_Koo WIZnet ·
Hi jhinkle .
Thank you for pointing this out.
Regarding your original question about
Sn_SR,Sn_SR == SOCK_UDP (0x22)only indicates that the socket has entered UDP mode. It is not a busy/ready indicator for the first transmit, and it does not by itself guarantee that the first DHCP DISCOVER will be transmitted immediately after socket open. So seeing the same0x22value before and after the delay is not unexpected.For checking whether a transmit operation actually completed,
Sn_IRis generally more relevant thanSn_SR, becauseSn_IRreflects the SEND result path such asSEND_OKorTIMEOUT. However, after reviewing the ioLibrary code,sendto()already appears to perform its normal SEND completion handling internally. So this does not look like a simple case of missingSn_IRchecking insidesendto().At this point, what looks more important is the sequence around the first DHCP transmit after socket open. In the current flow, the socket may be opened and the first DHCP DISCOVER may follow very soon afterward, so we will review whether this path needs any improvement.
If you prefer not to modify the ioLibrary files directly, a practical workaround for now would be to delay or defer the first DHCP processing in the user application code. For example:
DHCP_run()on a later main-loop cycle or timer tick,
