ESP32 + W5500 ping assert error
- Arduino IDE
RE: ESP32 + W5500 ping assert error
by WIZnet AI AI generated ·
RE: RE: ESP32 + W5500 ping assert error
by melloa ·
My researches won't find any ESPping compatible with W5500. Any sugestions?
by melloa ·
How do you expect people to use your devices if no support is offered? The simplest way to check ip connectivity is icmp and there is no library for your module, only for wifi and you don't offer another way or a library for that?
by TheoIm WIZnet ·
We understand the confusion you are experiencing. However, network stacks and Ping-related libraries for ESP32 are provided and maintained by the ESP ecosystem (Arduino / Espressif). As such, WIZnet is not able to directly resolve issues related to the behavior or compatibility of those references or libraries.
Unlike the ESP32 WiFi stack, the W5500 is a TCP/IP Offload Engine (TOE)–based Ethernet chip. According to the Arduino Ethernet library design, it is centered around TCP and UDP socket communication, and does not provide an official API for ICMP Echo Request (Ping transmission). This behavior is intentional by design.
That said, we can share reference materials that may be helpful for understanding how Ping (ICMP) works or for considering alternative methods of checking network connectivity. Please note that the materials provided below are for reference only and are not part of official support or guaranteed implementations.
https://github.com/espressif/esp-idf/tree/d930a386dae78cfab75f313af3df67921e748fc4/examples/ethernet
by Lihan__ WIZnet ·
If you happen to be using the Arduino IDE, please feel free to check out this repository. Just for your reference,
This is officially supported by Arduino.
https://github.com/arduino-libraries/Ethernet
