W5500 and UWB not Working Together with ESP32
RE: W5500 and UWB not Working Together with ESP32
by Ali Hamza Malik ·
#include <SPI.h>
#include <Ethernet.h>
#include “DW1000Ranging.h”
// SPI pins for W5500
#define HSPI_SCK 14
#define HSPI_MISO 12
#define HSPI_MOSI 13
// Chip Select pin for W5500
#define W5500_CS 15
// SPI pins for UWB
#define SPI_SCK 18
#define SPI_MISO 19
#define SPI_MOSI 23
#define DW_CS 5
// Control Pins for UWB
const uint8_t PIN_RST = 27; // reset pin
const uint8_t PIN_IRQ = 34; // irq pin
const uint8_t PIN_SS = 5; // spi select pin
// Ethernet configuration
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // MAC address for W5500
IPAddress ip(192, 168, 1, 178); // Static IP address for W5500
IPAddress myDns(8, 8, 8, 8); // DNS server
IPAddress gateway(192, 168, 1, 1); // Gateway
IPAddress subnet(255, 255, 255, 0); // Subnet mask
EthernetServer server(23); // Create a server that listens on port 23
// Calibration Range for UWB
float calibrationRange = 0.78;
void setup() {
Serial.begin(115200);
delay(1000);
// Initialize the SPI bus for W5500
SPI.begin(HSPI_SCK, HSPI_MISO, HSPI_MOSI);
// Initialize W5500 Ethernet module with static IP
Serial.println(“Initializing W5500…”);
Ethernet.init(W5500_CS);
Ethernet.begin(mac, ip, myDns, gateway, subnet);
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println(“W5500 not found. Check wiring.”);
} else if (Ethernet.linkStatus() == LinkOFF) {
Serial.println(“Ethernet cable is not connected.”);
} else {
Serial.println(“Ethernet initialized successfully.”);
Serial.print("IP Address: ");
Serial.println(Ethernet.localIP());
server.begin(); // Start the TCP server
// Initialize SPI for UWB
SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI);
DW1000Ranging.initCommunication(PIN_RST, PIN_SS, PIN_IRQ);
// Define the sketch as anchor
DW1000Ranging.attachNewRange(newRange);
DW1000Ranging.attachBlinkDevice(newBlink);
DW1000Ranging.attachInactiveDevice(inactiveDevice);
DW1000.enableDebounceClock();
DW1000.enableLedBlinking();
DW1000.setGPIOMode(MSGP0, LED_MODE);
// Start the module as an anchor
DW1000Ranging.startAsAnchor(“82:17:5B:D5:A9:9A:E2:9C”, DW1000.MODE_LONGDATA_RANGE_LOWPOWER);
void loop() {
DW1000Ranging.loop();
// Check if a client has connected
EthernetClient client = server.available();
if (client) {
Serial.println(“New client connected”);
while (client.connected()) {
// Get the range data
String message = getRangeData();
// Function to get the range data
String getRangeData() {
String data = “”;
if (DW1000Ranging.getDistantDevice()) {
data += "from: ";
data += DW1000Ranging.getDistantDevice()->getShortAddress(), HEX;
data += "\t Range: ";
data += DW1000Ranging.getDistantDevice()->getRange() * calibrationRange;
data += " m\t RX power: “;
data += DW1000Ranging.getDistantDevice()->getRXPower();
data += " dBm”;
return data;
void newRange() {
Serial.print(“from: “); Serial.print(DW1000Ranging.getDistantDevice()->getShortAddress(), HEX);
Serial.print(”\t Range: “); Serial.print(DW1000Ranging.getDistantDevice()->getRange() * calibrationRange); Serial.print(” m”);
Serial.print(“\t RX power: “); Serial.print(DW1000Ranging.getDistantDevice()->getRXPower()); Serial.println(” dBm”);
void newBlink(DW1000Device* device) {
Serial.print(“blink; 1 device added ! → “);
Serial.print(” short:”);
Serial.println(device->getShortAddress(), HEX);
void inactiveDevice(DW1000Device* device) {
Serial.print("delete inactive device: ");
