my wiz750sr-ttl module wont connect when i use a different computer
RE: my wiz750sr-ttl module wont connect when i use a different computer
by Aimee0 WIZnet ·
hello, can you ping the module’s IP from the Ubuntu PC?
RE: RE: my wiz750sr-ttl module wont connect when i use a different computer
by Aimee0 WIZnet ·
Sorry for the late reply.
Unfortunately, we do not support the configuration tool on Linux.
You can configure and use a Windows 10 environment with a virtual machine in Ubuntu.
by arcane b ·
i used windows 10 to configure the the module and it worked when i connected to it on the computer i configured it on but when i plug it in to any other computer i cant connect to it
by arcane b ·
could there be a firewall issue or something?, i also tried to ping it but it doesnt seem to be getting a response
by Aimee0 WIZnet ·
can you tell me how to organize the network below?
and what did you use to check it was connected? (ex. Hercules…)
by arcane b ·
I am using the python socket library to connect to the ethernet module.
is there a format that the IP addresses need to be in for them to be able to talk to each other? i am curious as to what information would be gained from knowing the IP addresses?
by Aimee0 WIZnet ·
It was to make sure that the IP address was matched in the same band.
Change the PC’s IP network settings to Static and perform a Ping test:
Control Panel - Windows Defender Firewall - Turn Windows Defender Firewall on or off - Turn off private and public network firewalls
by arcane b ·
does it being matched in the same band mean that they are both TCP/IPv4?
and do you by chance know how to do the same process but with linux?
by Aimee0 WIZnet ·
As a example, module’s ip is 192.168.11.3 and PC_1’s ip is 192.168.11.10 PC_2’s ip is 192.168.10.10.
module ↔ PC_1 will work
module ↔ PC_2 will not work. (PC_2 have to config as 192.168.11.XX)
by arcane b ·
im quite new with this whole thing so forgive my amateurish question, but how do you know if a IP is matched in the same band that i could look for?
