w5500 module with green led on without cable connected
RE: w5500 module with green led on without cable connected
Remove cable from the W5500 end having RJ-45 jack unplugged?
RE: RE: w5500 module with green led on without cable connected
by heins ·
when i remove the rj45 cable the light stays on!
The question was about at which end you remove cable from the connector. Is it W5500 end (W5500 module connector), or router end (router’s connector)?
by heins ·
end of w5500
Ok, green LED is usually link LED. It is lit when chip sees the carrier on the RX lines. After you remove the cable, what PHYCFGR reads? Next question, if you power cycle (turn off and he on) the device wiht W5500 does it start working, or still has green LED on and not working?
by heins ·
Could you give me a light on this, I’ve been using it for a short time, yes the led is still on
Datasheet, page 42. W5500 will show you what it thinks about the link and PHY status in general.
by heins ·
when I call the function getgetPHYCFGR() it returns me 0xff in hex,
however, even trying to set the register to 0xD8 with the setPHYCFGR() function, nothing happens.
I think there is a problem with the chip, so SPI communication itself may not work.
Could you please read the VERSIONR register?
VERSIONR (W5500 Chip Version Register) [0x0039]
VERSIONR always indicates the W5500 version as 0x04.
by heins ·
when I call the readVersion() function it also returns me 0xff in hex
Surely SPI does not work as @irina_kim suspected.
Can you please look at this and check power supply for your device to ensure it is not the cause of weird issues.
