LAN data transfer speeds
RE: LAN data transfer speeds
Datasheet says
I suspect there’s mistake, and 33.3 is maximal guaranteed frequency, not minimal.
And the bottleneck may not be in the LAN speed, the bottleneck is in SPI interface and socket management. Max SPI speed is achieved in VDM mode, but before doing it you must read several registers making several requests (which may also be optimized).
And yes, W5500 (and other chips of this family) heats because it has PHY drivers inside.
by spontomdela ·
I work with the W5500 chip at a speed of 60Mbps via the SPI interface, no data loss. Even if only one socket is active, will I be limited to 15Mbps?
RE: RE: LAN data transfer speeds
If you’ll manage and report it you will be the first officially breaking the limit
