Wiznet w5500 schematic layout verification
RE: Wiznet w5500 schematic layout verification
by Alan WIZnet ·
The circuit looks fine. However, when designing a PCB, the Ethernet line should be designed as a differential pair. It is recommended that the impedance be adjusted to 100 ohms.
RE: RE: Wiznet w5500 schematic layout verification
by iomkar ·
Hi Alan,
Thank you for your response. We are facing one more issue while using wiznet w5500. We have observed that whenever inductive load such as contactors are triggered near w5500 circuit,
it resets. We had put the query before on this link : W5500 False Reset due to AC switching noise - #6 by ayushjain1912 . Please let me know if you may add anything more.
Regards,
Omkar
by Alan WIZnet ·
Is “Reset Line” the W5500’s “Reset Line”?
Every time the inductive load you mentioned is loaded, the surge power splashes too hard… It doesn’t look normal. I think we need to turn it on properly first. Isn’t the GND line firm?
I replied to you via link.
by iomkar ·
Hello Alan,
Thank you for your response. Yes, the reset line is W5500 reset line. By “turn it on properly first”, do you mean W5500 or the inductive load in this scenario? We have the GND plane on the entire PCB.
by Alan WIZnet ·
It meant that we need to get all the VCCs right first. It is strange that the VCC bounces like the image above depending on the induced load. It’s sticking out too much.
by iomkar ·
Hello Alan,
In our system, input supply is clean. There is no VCC bouncing as shown in your image. We have microcontroller which works fine, only w5500 resets in above case.
by Alan WIZnet ·
Is that so? Can you tell me a more accurate situation? I don’t think I know the exact situation.
by Alan WIZnet ·
If you send me the whole circuit diagram, it will be easy for me to figure it out.
by Omkar Bhatt ·
Did you find a solution to this? If so, please help.
I am facing a similar issue, despite having a snubber and MOV across the contactor which is being operated through a relay (with an amp and flyback diode) and a shielded ethernet cable and proper earthing - the MCU doesn’t reset but the ethernet connection is lost upon contactor operation especially while turning on.
Thanks in advance.
by iomkar ·
Hii,
Unfortunately the problem persists. So we have made a peace with recovery method. Whenever w5500 resets due to contactor switching, we connect it immediately. Let me know if you have tried any other method.
Thanks,
Omkar
by Omkar Bhatt ·
I did get it to work - but not ideally.
I wasted a lot of time making a controller board using this chip only to learn that it may be good for consumer applications and not industrial or rugged applications (although advertised otherwise).
Also, if you are aware of any alternatives for an industrial environment, please let me know - what do you think about the ENC28J60?
Thanks, I hope this helps.
by Philm001 ·
Hello everyone,
I apologize for posting in this topic but I am unable to create a new topic.
Anyways, I need some clarification regarding one of the pins for the W5500.
In the datasheet, it says that Pin 23 needs to be tied to ground while on the reference schematic it is not connected to anything.
So what should I do regarding this pin
by bruno WIZnet ·
Here is the response concerning your inquiry about the W5500’s RSVD pin.
