WIZnet-PICO-AWS-C on W5500-EVB-Pico2
RE: WIZnet-PICO-AWS-C on W5500-EVB-Pico2
by WIZnet AI AI generated ·
by multistars7 ·
Cortex-Debug did not allow the program to be specified.
I specified aws_iot_mqtt.elf as executable.
"executable": "${workspaceRoot}/build/examples/aws_iot_mqtt/aws_iot_mqtt.elf"
But the GDB Server does not work.
OpenOCD: GDB Server Quit Unexpectedly. See gdb-server output in TERMINAL tab for more details.
The GDB Server works with the example blnk.
RE: RE: WIZnet-PICO-AWS-C on W5500-EVB-Pico2
by multistars7 ·
Instead of creating two elf files, aws_iot_http and aws_iot_mqtt, in one project,
could you split them into two projects?
WIZnet-PICO-AWS-C/examples/aws_iot_mqtt
WIZnet-PICO-AWS-C/examples/aws_iot_http
I would like the top-level CMakeLists.txt to look like this:
# Set project informations
project(aws_iot_mqtt C CXX ASM)
I think many users who buy the W5500-EVB-Pico2 are not familiar with makefiles.
As it is, you can only write executable files.
Thank you in advance.
by TheoIm WIZnet ·
We are unable to provide guidance regarding debugging using the J-Link GDB Server. Our support is limited to the usage of WIZnet chips. It would not be appropriate for us to explain how to use third-party debuggers, as it may lead to potential errors. We kindly ask for your understanding.
