w5500 not working on SPI1?
RE: w5500 not working on SPI1?
Why SPI “1”? When W5500 accepts the byte, it puts 0x01, 0x02, and 0x03 onto the MISO. You have 0x00, 0xfa, 0xfa therefore something is broken in your SPI communication. As long as you have such scope/logic analyzer, show at least one full access cycle with all four signals. Homework for you to deconstruct what you see in there and prove MOSI is correct (or find the issue and fix it).
RE: RE: w5500 not working on SPI1?
by emcdee ·
Ah many thanks for the starter pointer.
Yea SPI1 is alternate SPI bus on Electron, as such you have to swap out SPI1.begin, etc. funcs.
Ok, and I’ve updated what I believe is a full access cycle, above (after logging all 4 channels on analyzer - clock, SS, MOSI, MISO; means bit less precision but analyzer still picks it up).
Where? I expect 4 separate time-aligned signal logging.
by emcdee ·
Apologies, you mean the enable and clock signals aren’t shown in data table, beyond miso and mosi?
Else lemme try to show trace output in a better video preview -
by emcdee ·
And here’s the SPI1 setup funcs -
I do not need video preview. I need one read/write cycle in picture which timing and waveform I can analyze.
by emcdee ·
Ah ok let’s try,
Overview (channel IDs) -
First two frames -
Close up of 1st frame -
Close up of 2nd frame -
I’m not sure why the 1st frame is ‘blank’ from MOSI (despite getting a MISO), tho SPI in Mode-0 if that helps… and SPI1 is dedicated to to just this w5500.
Thanks for your patience / support
MISO can’t be low level when chip is deselected. What W5500 module do you use, and what is connection circuit of everything into SPI bus?
by emcdee ·
Appreciate that insight,
Using the w5500 >> 48-LQFP (7x7)
Pull-up / down here just means in hardware setup, but those overrode by pinMode as output high.
Else in code the CS pin in code per w5500 lib -
[w5500.cpp]
And -
[w5500.h]
I am almost convinced this is your problem. Value being read for MR - 0x05 - may be correct one if reserved bits read as 1. So you have problem with MISO in the first, second, and third sections (bytes) of the transaction.
by emcdee ·
Oh, now I can set those (int, reset) to stay at a value (override pull-up/down resistors), and I had them as OUTPUT High to avoid interfering w/ bus -
