Updating WizFi360 via AT+CIUPDATE command or SPI
RE: Updating WizFi360 via AT+CIUPDATE command or SPI
Hello @hkm_mn
The SPI interface can also use the same AT commands as the UART interface.
Therefore, firmware update is possible with ‘AT+CIPUPDATE’ through the SPI interface.
For the response to ‘AT+CIUPDATE’, refer to ‘3.3.21 AT+CIUPDATE’ in the document below.
RE: RE: Updating WizFi360 via AT+CIUPDATE command or SPI
by hkm mn ·
Thank you for your reply. From the documentation, the AT+CIUPDATE does following steps:
1: find the server
2: connect to server
3: get the software version
4: start updating
Could you please confirm that the command also checks integrity of downloaded firmware between steps 3 and 4?
Hi @hkm_mn
Yes, check the integrity in step 4.
by hkm mn ·
Hello again,
I have a problem with OTA firmware update. Using the latest release from Release/Binary at master · wizfi/Release · GitHub , I Issue following command:
and the response I get is as follows:
the module then sends
+CIPUPDATE:1every 5 or so seconds. I’ve tried updating without specifying URL or withAT+CIUPDATE="http://wizwiki.net/download/WizFi360/O11/WizFi360_SDK.img"or withAT+CIUPDATE="http://wizwiki.net/download/WizFi360/WizFi360_SDK.img"but those always result in error after+CIUPDATE:3.After rebooting the device, I’m still at version 1.1.1.7 like before the update:
Hi @hkm_mn
Would you like to try OTA by entering this address?
by hkm mn ·
It worked! I’ve analyzed the problem a bit and found out that the culprit was that my web server was using HTTPS instead of HTTP.
Would it be possible for you to add ability to AT+CIUPDATE command to accept firmware from HTTPS sources? Today almost all of web is HTTPS-based and having a HTTP exception in our server’s configuration is troublesome. Also, we really need to host the firmwares ourselves to have strict control on what firmware version our devices are running. We can’t use always-latest firmware from your address because in case of incompatibility on our end we’ll be left with unresponsive devices and need to service them on-site which is costly for us.
