Cannot receive ethernet packets
RE: Cannot receive ethernet packets
by scott WIZnet ·
Hi gthind
Your circuit is not expected to be problematic. Your problem may be to check the PCB Gerber file.
Can you upload the Gerber file here? The picture is fine, too.
Scott
RE: RE: Cannot receive ethernet packets
by gthind ·
Hi Scott,
I just started working on the new layout, but as reference I’ve an R&D board file. Which I think is incorrect according to W5500 layout design rules.
Thanks, gthind
by scott WIZnet ·
I think it’s very bad.
Please refer to the URL below.
http://wizwiki.net/wiki/doku.php?id=design_guide:hardware:start
by gthind ·
Hi Scott,
I did the PCB layout for that board again with W5500 IC. I kept the tx+ tx- traces distance 10mil.
by scott WIZnet ·
Dear gthind
I think you designed it well. What layer is this PCB?
Do you have any questions?
thank you.
by gthind ·
This is 4 layer PCB with area underneath RJ45 completely isolated. Thanks, GT
