Problem init WizFi250
RE: Problem init WizFi250
I apologize for late reply.
It is possible to communicate with SPI between WizFi250 and Mega2560.
You should set SPI mode before SPI communication.
I think it is helpful. plz check below link.
http://wizwiki.net/wiki/doku.php?id=products:wizfi250:wizfi250pg:start#at_mspi
Best Regards,
Tom
by Werk AG ·
Hi Tom, tanks for your reply.
This is from the document referred in your answer (which I already had read)
"AT Command Set
This section provides a list of WizFi250 AT commands and their effects. Users can input commands and parameters through USART line
As I tried to say, I designed my board without any connection to the USART lines of the WizFi250 module. In my project I’m already using all the 4 uarts of the Mega, this was the main reason why I choose an SPI WiFi module. So, how I can send AT command’s to make it work in SPI mode?
Is it a requirement having the USART lines connected from the MCU to the WizFi module to make it work in SPI?
After having the module powered, should I see any WiFi network?
Answers to my questions will be greatly appreciated. This project is on hold until I solve this question.
Once again, thank you.
RE: RE: Problem init WizFi250
by Werk AG ·
I’m really sad about the lack of support for this product.
I don’t have the development board, I’m just trying to design a product that uses these WiFi modules. It is so hard to reply to costumers answers within an acceptable time frame?
Hi, Werk
I am aplogize sincerely…
I have no excuse for late answer.
I hope you it is helpful.
WizFi250 supports SPI interface and of course SPI line !
H/W connection should be like below.
Arduino (SPI Master) ---- WizFi250 (SPI Slave) ------- Remarks------------------
Allocate your GPIO ------- GPIO14 (50) --------------- WizFi250 Data Ready
MSPI_MISO ----------------- SPI_MISO (21) ------------- SPI Master In/Slave Out
MSPI_CLK ------------------- SPI_SCK (22) ------------- SPI Clock
MSPI_CS ---------------------- SPI_SS (24) --------------- SPI Chip Select
MSPI_MOSI ----------------- SPI_MOSI (23) ------------- SPI Master Out/Slave In
GND ----------------------------- GND ------------------- Command Ground
And, we provide a SPI interface s/w examples based on arduino.
github.com/Wiznet/Arduino_WizFi2504
I hope you it will be helpful to solve your qeustions.
If you have other problems, ask anytime !!!
Thanks,
