Problems initializing TX Buffer
RE: Problems initializing TX Buffer
You assume that “initialized” means set to 0. It is not correct assumption.
Your TX buffer is initialized.
It says that TX buffer has 2K free space, its RD address is ee9c and its WR address is ee9c. You should start writing at this address, and increase WR pointer with the number of bytes. Then issue SEND command.
If you do not do it and just issue SEND command, W5500 sees that the difference between pointers is whole buffer (ee9c & 7ff) - (ee9c & 7ff) which is 0, but 0 means one full leap through buffer = 2K in size.
Chip is behaving properly.
by Skyfox ·
Thank you very much for your reply. It now works as you said. I think I got a bit misguided by the post I quoted earlier where it said: [quote][…]but I’m pretty sure that the pointers contain 0 after reset[…][/quote]
