Macro definition problem in W5500 library function
RE: Macro definition problem in W5500 library function
This must be preparation of the 3rd byte in the SPI transaction. 0x08 is the socket 0 register set. If you add channel (socket) number shifted left by 5 bits you will get 16-bit address + bank identification for respective channel (socket) ready to shift to the SPI. The only additionally needed is set bit for write and 2 bits for transfer mode type.
RE: RE: Macro definition problem in W5500 library function
by Bohu-Tang ·
Thank you very much for solving my confusion with your answer.
by Bohu-Tang ·
Sorry,Eugeny,I just looked at the W5500 datasheet and Socket 0 Register corresponds to 0x01 and 0x08 corresponds to the Reserved field.Am I looking for the wrong register location?
You are looking into wrong place. Read the 2.2 of the datasheet, it will answer your question. 0x08 is bank (block) address of 0x01 shifted 3 bits left because lower 3 bits are occupied by other flags.
by Bohu-Tang ·
Thanks a lot Eugeny. Your answer clears up my confusion.
