At commands
RE: At commands
by cliff ·
WizFi250 is wifi-module.
So, WizFi250’s role is connect and configure AP.
Can I send AT commands to wizfi250 without having a PC? If yes, in which mode the wizfi has to be set? Ap, station, OTA? UDP, TCP? port number?
→ I don’t know what is your question exactly.
But, do you want to know that is possible control from MCU? If it so, yes.
Can I control GPIO pins via data mode?
→ It also possible, but I think that is related question with MCU.
Can I have IF statements? For example : " if GPIO pin 1 = high THEN make GPIO pin 6 LOW"
→ Yes, it is possible.
If the wizfi is running in data mode and there is a communication between android and wizfi+MCU via UART, can the wizfi read the status of GPIO pins and send it through UART to the android or MCU?
Thanks, regards
RE: At commands
by soellicha ·
Yes, I need to send AT commands from MCU to the wizfi.
So far I have connected the MCU to wizfi, I receive the message from wizfi “wizfi 250 version 1.0” So it means that they are communicating quite well.
Because as far as i know if I send data from MCU to wizfi they just go as data and go through the UART and end up to the peer device such a smart phone. HOW do I send the data as AT commands?
Note: I cannot connect the wizfi to a telnet/serial like putty with my PC, in order to send any other At commands.
Can you help please?
