W5500 commands over TCP
RE: W5500 commands over TCP
Datasheet explains how communication is being done in TCP, UDP and RAW modes.
Reuse any working example for TCP communication. The only issue could be setting gateway address (as gateway does not exist in your configuration), and I think setting (leaving it) 0.0.0.0 must be ok. If not, set it to the IP address of the PC you are communicating with - I think it will respond to the ARP packets if they are about its IP address.
Telnet is network protocol and it is built upon the TCP. You will have to implement it in software.
