[W5500] Sn_CR 레지스터가 초기화 되지 않습니다
RE: [W5500] Sn_CR 레지스터가 초기화 되지 않습니다
by ykcho6424 ·
추가 확인을 해 보면 Sn_CR에 0x10(SOCK_CLOSED)을 write을 하면 해당 command를 인식하여 처리한 뒤 0x00으로 설정이 되어야 하는데
그대로 0x10으로 되어있는 것을 보면 command를 인식하지 않아 처리하지 않았기 때문에 값이 clear되지 않고 0x10 그대로 있는 것 같습니다.
혹시 command를 인식하지 않는 사항은 언제 발생하는지요…
You would probably get more help if you write in English. Regarding your issue I would do the following: when CR is stuck in value 0x10, perform dump of all registers of all sockets to identify their state and see if there’s anything unusual. I would dump registers using generic register read command to ensure
getSn_CR(sn)operates properly and there’really 0x10 is the respective register location.RE: [W5500] Sn_CR 레지스터가 초기화 되지 않습니다
by ykcho6424 ·
Translation with google translation and sentences are not smooth.
please understand.
I added a code to the part where the problem occurred and confirmed it and registered a sentence.
[code…]
DEBUG((EFI_D_ERROR, “[YKCHO] close, 1, getSn_SR(sn) : 0x%x, getSn_CR(sn) : 0x%x\n”, getSn_SR(sn), getSn_CR(sn)));
setSn_CR(sn,Sn_CR_CLOSE);
DEBUG((EFI_D_ERROR, “[YKCHO] close, 2, getSn_SR(sn) : 0x%x, getSn_CR(sn) : 0x%x\n”, getSn_SR(sn), getSn_CR(sn)));
while( getSn_CR(sn) ){
DEBUG((EFI_D_ERROR, “[YKCHO] close, 3, getSn_SR(sn) : 0x%x, getSn_CR(sn) : 0x%x\n”, getSn_SR(sn), getSn_CR(sn)));
DEBUG((EFI_D_ERROR, “[YKCHO] close, 4\n”));
Even if i do [setSn_CR(sn,Sn_CR_CLOSE)] or [setSn_CR(sn,Sn_CR_OPEN)], try reading getSn_CR(sn) and the value will not cleared.
Even if i do [setSn_CR(sn,Sn_CR_CLOSE)] or [setSn_CR(sn,Sn_CR_OPEN)], if i check the getSn_SR(sn) value, it is in the SOCK_CLOSED state.
Naturally, nothing works.
I added log again.
[LOG]
[YKCHO] close, 1, getSn_SR(sn) : 0x0, getSn_CR(sn) : 0xC0
[YKCHO] WIZCHIP_WRITE, spi_data[0] : 0x00, spi_data[1] : 0x01, spi_data[2] : 0x2C, wb : 0x10
[YKCHO] spi_transfer, write_buffer[0] : 0x0
[YKCHO] spi_transfer, write_buffer[1] : 0x1
[YKCHO] spi_transfer, write_buffer[2] : 0x5
[YKCHO] spi_transfer, write_buffer[3] : 0x10
[YKCHO] WIZCHIP_READ, spi_data[0] : 0x00, spi_data[1] : 0x03, spi_data[2] : 0x28
[YKCHO] spi_transfer, read_buffer : 0x0
[YKCHO] WIZCHIP_READ, spi_data[0] : 0x00, spi_data[1] : 0x01, spi_data[2] : 0x28
[YKCHO] spi_transfer, read_buffer : 0x10
[YKCHO] close, 2, getSn_SR(sn) : 0x0, getSn_CR(sn) : 0x10
[YKCHO] close, 3, getSn_SR(sn) : 0x0, getSn_CR(sn) : 0x10
by ykcho6424 ·
It was my mistake.
It was socket register address calculation error.
Thank you for your help.
