W5500 stuck on Socket Close Function - while( getSn_CR(sn) )
RE: W5500 stuck on Socket Close Function - while( getSn_CR(sn) )
Prove that SPI communication functions properly by reading VERSIONR register and getting 0x01, 0x02, 0x03 and 0x04.
RE: RE: W5500 stuck on Socket Close Function - while( getSn_CR(sn) )
by ClariceStarling ·
This is the SPI timing for tihs code its okay for chip version! But what is the problem
What is the value of
snhere? Not the one you may think of, but real value reported by the MCU?RE: RE: W5500 stuck on Socket Close Function - while( getSn_CR(sn) )
sn = 0;
But reading the version of chip
register level code returns 0x04. It ok as you can see in my previous message (Logic Analyzer)
But this function returns 0x01 → chipVersion = getVERSIONR();
Is this a SPI function problem ?
Then look at what is going on the bus when you perform this call. Did you select the right chip within the library?
Yes there is W5500. Its ok.
Oh my god what is this function?
this function cannot read the last byte ( chipVersion = getVERSIONR(); )
Your definition is framed within
#ifndef. You are not guaranteed to have exactly this value defined if it was defined somewhere else beforehand. Dig into library and put diagnostic outputs into its flow to prove it does required thing.RE: W5500 stuck on Socket Close Function - while( getSn_CR(sn) )
I did but there is no change
If you’d do this (second thing I said) you’d know how
getVERSIONR();works for you, what it does, and where’s a problem.RE: W5500 stuck on Socket Close Function - while( getSn_CR(sn) )
Something feels wrong in the library.
I think the SPI buffer is not being cleared.
That’s why I cleaned it by reading after each sending process.
I can connect now!
But a new problem arose.
When I send data with the send function after the connection process, the data is sent only once. When I want to send it later, the send function returns the following value
#define SOCKERR_SOCKSTATUS (SOCK_ERROR - 7) ///< Invalid socket status for socket operation.
What does it mean “later”? What status the socket has when this “later” happens?
sorry for wrong explanation
It sends data only once, but when I try to send it a second time, it gives the -7 error.
