Issue with W7500P Peripheral Example - WZTOE
RE: Issue with W7500P Peripheral Example - WZTOE
Hi.
What example in WIZTOE?
http? , Loopback??
by ezheng ·
I only looked at examples of DHCPClient and LoopbackTest.
by ezheng ·
At the example of WZTOE_DHCPClient:
mdio_init(GPIOB, MDC, MDIO ) is called by main(). The following code are from subroutine mdio_init():
But when I refer to datasheet and reference manual of W7500P, which do not define the alternate funtion of PB_14 and PB_15 Pin.
The following code also are from main(), I could n’t find the definition of pad control register with address of (0x41003070) and (0x41003054).
ifdef W7500P
*(volatile uint32_t *)(0x41003070) = 0x61;
*(volatile uint32_t *)(0x41003054) = 0x61;
#endif
So, I hope to get support and advice, Please!!!
