Issue with access to some W5500 registers
IO Modules
IO Modules
RE: Issue with access to some W5500 registers
by WIZnet AI AI generated ·
by Aimee0 WIZnet ·
Thank you for your inquiry. To help diagnose the issue, please check the following points:
Are you using the latest version of WIZnet’s ioLibrary?
Older versions may contain bugs related to register access. Please ensure you are using the most recent release from the WIZnet GitHub repository.
Have you completed all necessary initialization steps for the WIZnet chip before accessing the common registers?
Make sure your SPI communication is set to Mode 0 or Mode 3 only.
W5500 supports only SPI Mode 0 and Mode 3. Using other modes may result in incorrect timing and communication failures.
