RE: WIZ750SR-100 Configuration Issue with Firmware 1.4.x
by Aimee0 WIZnet ·
Hello
We have reviewed the configuration file you provided and would like to clarify a few points to help us reproduce the issue.
1) Your current network settings are:
With a /13 subnet mask, both IP addresses are considered to be on the same subnet. Could you please confirm that this is the intended network configuration?
2) Did exactly the same configuration work correctly with firmware v1.3.3 (or earlier), without any modifications?
3) After saving the configuration with v1.4.2 or v1.4.5:
4) Could you also let us know:
This information will help us reproduce the issue and investigate whether it is related to the firmware or the network configuration.
Best regards,
RE: RE: WIZ750SR-100 Configuration Issue with Firmware 1.4.x
by LukasF ·
thanks for the fast answer!
Here the requested information:
1. Yes
2. Yes
3. a) I do not know if the device made a reboot.
3. b) LED LD4 (green) and LD1 (red) still on. LD2 (blue) NOT on.
3. c) I do not know yet how to make a factory reset without being able to discover the device. I tried to connect the BOOT pin with ground, but no changes in LED pattern, and still not able to discover the device.
4. brand new boards that came with 1.4.2
The host PC has several network adapters / IP addresses, I selected: 172.20.0.165/16
I did try to configure another board, this time I just changed "Operation Mode" from "TCP server" to "UDP" and the device is now unreachable and the blue LED is off.
by LukasF ·
1. Yes
2. Yes
by LukasF ·
Please propose a solution to this problem as soon as possible, as it is time-sensitive for us.
by Aimee0 WIZnet ·
Apologize for the delayed response.
To help us provide faster support, we would appreciate it if you could send the results of the following tests to aimee@wiznet.io.
https://github.com/Wiznet/WIZnet-S2E-Tool-GUI/releases/tag/v1.5.8
Please send us the test results by email, or let us know your email address. We will review them as quickly as possible and provide further assistance.
