W5500 compatibility
RE: W5500 compatibility
Hi.
Please you check the registration Static IP in DHCP router.
by dodge55 ·
I didn’t understand your response. DHCP does work at my house, as I have laptops and tablets that get IP addresses. However, those might be encrypted, which may be part of the problem.
by Coccoliso ·
hi,
MAC address is the only registry that may derail a dhcp.
Ensure it is set correctly because in some router a MAC set FF-FF-FF-FF-FF-FF or 00-00-00-00-00-00 can give you this problem.
What does it mean?
You have to figure out if it does not work the discover or the lease phase.
All other net common registry (IP, net mask and gateway ) must be filled at 0 before a discovery.
