W5500 communication failure
RE: W5500 communication failure
by Aimee0 WIZnet ·
Is the issue that the web server is not opening properly?
If so, could you please check whether the same issue occurs when using different web browsers, such as Google Chrome and Microsoft Edge?
Also, please refer to the HTTP Server example below and compare your configuration and implementation with the example.
https://github.com/Wiznet/ioLibrary_Driver/tree/master/Internet/httpServer
