Wiz550io missing data from RX buffer
RE: Wiz550io missing data from RX buffer
by Coccoliso ·
this happens because sometimes the first part of the request (the header) is sent immediately while the contents thereof undergoes a slight delay. If you’re start immediately in reading missing next parts.
So wait for major chunk size then start or I prefer try doing a seek in the buffer without moving the read pointer.
A GET REQUEST Header is like this …
… then you search for “Connection:” then
seek for “GET /” and take that position
seek for “POST /” and take that position
seek for " HTTP/"
move the read pointer after you have correctly receive the full content and then can prepare the answer.
by lsdave ·
I am sending a GET request from a web browser.
Safari from either my iPhone or Macbook i end up reading something like the following from the buffer in the Wiznet
[code]Listen function started
RX Buffer Pre_Write: 28788
RX Buffer Post_Write: 29153
Content:ion/xml;q=0.9,/;q=0.8
User-Agent: Mozilla/5.0 (iPhone; CPU iPhone OS 9_2_1 like Mac OS X) AppleWebKit/
1.1.46 (KHTML, like Gecko) Version/9.0 Mobile/13D15 Safari/601.1
cept-Language: en-ca
che-Control: max-age=0
nection: keep-alive
anguage: en-US,en;q=0.8
-©þIDSå•Z¿ÁNòÙvv2f~†òù•‡±ò?øl¾ùBºµÌz±¼249môèÊ;@µ( ƒŠPw©’hÊ µ
Z@OÖÇy¤˜†Ä
Socket Close!
Sn_Port: 80
nection: keep-alive
Language: en-US,en;q=0.8
Z@OÖÇy¤˜†Ä
Socket Close!
Sn_Port: 80
Socket Close!
Sn_Port: 80
[/code]
I also notice that the RX buffer pointer seems to jump around depending on whats connecting to it.
When i use Chrome to try and connect to the wiznet the RX pointer always seems to be at 25955, and i update it after i’ve read it and then connect again, the pointer ends up back at 25955 again. even tho i read the pointer after i’ve written to it and display it out my debug under the RX Buffer Post_Write
If i use the ESP2866 TCP test client to connect to the wiznet the point increments correctly each time.
by lsdave ·
And this is the output of the degugging when i send a get request from Chrome.
by Coccoliso ·
at this point I have serious doubts about the way in which dialogues with the SPI.
Such as routines used to set and read the registers?
Routines are yours or you went from something that was already there?
Surely you miss something along the way because you always need two bytes to each new-line :
…if you spool while arriving you lose time in process the new-line so take a look at your sources.
by lsdave ·
It turns out i was reading the RX pointer incorrectly. I had the wrong Control byte being sent.
Everything is working great so far.
Thanks for your input Coccoliso! I appreciate it.
