Problem on receiving continuous buffer data from w5500
RE: Problem on receiving continuous buffer data from w5500
by randomizer ·
could you please share your code for sending and receiving data to/from the PC?
Look into the W5500 driving code. Most probably driver is looping looking for incoming data, and incoming data (RX size !=0) triggering driver executing sending code.
by JoergH ·
[quote=“randomizer”]could you please share your code for sending and receiving data to/from the PC?[/quote]void W5500_Write_TXBuf(unsigned char SocketNr, unsigned char *z, unsigned int len)
unsigned char /z[] =“Hallo ich bin da, wer noch?”,/ i, AdrHi, AdrLo;
unsigned int Adr;
// z[0]=169; z[1]=254;z[2]=101;z[3]=2;z[4]=0x13;z[5]=0x88;z[6]=0;z[7]=10;
TIMER_START(74);
#ifdef SEND_BLOCK
#else
#ifdef DEBUG
xil_printf(“Sn_TX_WR: Adr = 0x%x %x %x\n\r”, Adr, AdrHi, AdrLo);
#endif
#ifdef DEBUG
xil_printf(" TX-S%d Byte %d 0x%x = 0x%x %d %c\n\r", 0, i, i, z[i], z[i], z[i]);
#endif
SPI_Byte(z[i++]);
Adr++;
GPO_ptr[3] = 0x00 | FREQ_BIT ; // Freq
AdrHi = (Adr & 0xFF00)>>8;
AdrLo = (Adr & 0x00FF) ;
#ifdef DEBUG
#endif
#endif
TIMER_STOPP(74);
void W5500_Send_TXBuf(unsigned char SocketNr)
W5500_SocketCmd(SocketNr, 0x20);
void W5500_SocketCmd(unsigned char SocketNr, unsigned char Cmd)
void W5500_Read_TXBuf(unsigned char SocketNr)
// Nur 10 Byte lesen…
unsigned char z,/z[] =“Hallo ich bin da, wer noch?”,/ i, AdrHi, AdrLo;
unsigned int Adr;
void W5500_Read_RXBuf(unsigned char SocketNr)
unsigned int i, Adr, Len;
unsigned char z, AdrHi, AdrLo, LenHi, LenLo;
#ifdef DEBUG
xil_printf(“Adr = 0x%x %x %x\n\rLen = %d %x %x\n\r”, Adr, AdrHi, AdrLo, Len, LenHi, LenLo);
#endif
