WIZ550io sends lots of meaningless data from tcp
RE: WIZ550io sends lots of meaningless data from tcp
There should be something about improper programming of the W5500.
I propose you perform data dumping at the W5500 side to see if it receives data correctly.
Does it answer the same data?
But if “with waiting”? What is the difference?
That must be data sent by W5500, you must check your code at the W5500 side.
Guess - you use incorrect pointer to RX or TX buffers. I recommend you downloading W5100 datasheet and refer to chapter “Functional description” and check if your code complies with the algorithms described.
You should share code of the main loop (the best whole code related to W5500), and explain what exactly you expect this code doing.
