Configuration tool can't find module. [solved]
RE: Configuration tool can't find module. [solved]
by Coccoliso ·
If you do not connect to a router you need to use a cross cable.
the strange thing is that you can ping the module, however, should use a router and set as the gateway on both the router address.
by dalowiz ·
Maybe not so odd that it can ping. The W5500 datasheet says “However, user can use either type of cable to connect to other devices with auto-MDIX enabled, and the interface automatically corrects for any incorrect cabling.” The laptop, being pretty new, probably has auto-MDIX.
by dalowiz ·
I attached the module and the laptop to an Ethernet switch, and the configuration tool had no problem finding the module. Problem solved.
