Herramienta de configuración/Configuration tool WIZnet S2E v1.6.2.15
RE: Herramienta de configuración/Configuration tool WIZnet S2E v1.6.2.15
by TheoIm WIZnet ·
Thank you for your feedback.
The WIZ750SR firmware consists of two parts: Boot and Application (App). These versions must be compatible for the module to operate properly.
You mentioned updating the firmware from v1.2.4 to v1.4.5. If your module still uses Boot v1.2, it is not compatible with App v1.4.5.
The WIZnet S2E Configuration Tool updates only the application area, so the Boot version remains unchanged.
To resolve this compatibility issue, we recommend updating both Boot and App using the WIZISP Tool.
Firmware Update Instructions
Download the v1.4.5 Boot+App firmware from our GitHub releases page:
https://github.com/Wiznet/WIZ750SR/releases
File:
WIZ750SRv145_incl_Boot.bin(for WIZ750SR-TTL/RS232/RS485)Connect the WIZ750SR to your PC through UART2 (ISP port).
Run the WIZISP Tool, enter Boot mode, and upload the downloaded Boot+App firmware.
Once the update is complete, restart the module in Normal mode and verify its operation using the Configuration Tool.
For detailed instructions, please refer to our ISP Tool guide:
https://docs.wiznet.io/Product/Modules/Serial-to-Ethernet-Module/WIZ750SR/developers-guide-EN#flash-programming-using-wizisp-tool
Note: Please use the
Erase All Code Memoryoption as described in the guide. SelectingErase All Data/Code Memorymay erase the MAC address and configuration data.RE: Herramienta de configuración/Configuration tool WIZnet S2E v1.6.2.15
by WiznetSis ·
by WiznetSis ·
El área AppBoot está diseñada para admitir la actualización del firmware y ocupa 0x000 a 0x6FFF (parte inicial de 28 KB). SUPERIOR A v1.3 (V1.3.3, V1.4.5 etc)
PREGUNTA :
ROM2 SE PUEDE USAR lo que antes se usba en otras versiones ( 0xFF registros desde 0x7D00) ?
Voy a hacer una aplicacion que podria usar eso que ya no se usa en la ROM2.
En las versiones ANTERIORES a la V1.3 y ahi se usaba . 0x7D00 (0xFF)
RE: RE: Herramienta de configuración/Configuration tool WIZnet S2E v1.6.2.15
by TheoIm WIZnet ·
In WIZ750SR firmware v1.4.5, the memory range
0x00007D00–0x00007DFFis reserved for fixed interrupt-handler code used by the Boot and App firmware.Even if IROM2 is not shown as a separate memory region in the App target’s Keil settings, this does not mean that the address range is unused. The interrupt-handler code is placed there by the source and linker configuration.
Therefore, this region must not be overwritten with additional application code or data.
Please refer to the attached memory map for details.
To better understand your requirements, could you clarify how you intend to use this memory region?
If you briefly describe what you are trying to implement, we can suggest a suitable memory area and implementation approach.
by WiznetSis ·
Thank you for such a quick response.
The idea is to add functionality to the boards for certain development projects, which requires optimizing the entire microcontroller. I have consistently used your boards for various pieces of equipment, and now I am building upon the W7500P (and your hardware designs).
I previously asked whether it was possible to solder an EEPROM—since it is missing from the WIZ750SR—or if there was a model that included one.
Once again, thank you very much, and congratulations on your modules; they are always excellent pieces of hardware.
