No broadcast via config tool with two NICs enabled
RE: No broadcast via config tool with two NICs enabled
Hi Markus,
I guess it caused by priority of network adapters. (Metric)
it can be seen using ‘route print’ command on windows command console (can be entered by using a ‘cmd’ command)
Please Try adjusting each adapter’s ‘interface metric’ value in IP Settings tab (in Internet Protocol (TCP/IP) Properties).
(notice: lower metric means higher priority of network adapters)
Please refer to ‘How to change the interface metric on a network adapter’ in next link:
support.microsoft.com/kb/894564
support.microsoft.com/kb/299540
Regards,
Eric.
by Markus8 ·
Hi Eric,
first, thanks for the ‘metric’ hint! 10 points out of 10.
Still, if there is more than one adapter installed on the system, the broadcast is send only once, via the adapter with the highest priority.
This has to do something with the address: 255.255.255.255:50001 the broadcast message is send to. If I specify the adapter on the multicast socket and change the address to let’s say: 235.255.255.255:50001 the message is actually send via all adapters. Doing the same with the original address only sends it to the most prior adapter.
Do you have any hint on that one, too?
Regadrs,
Markus
