Problem with Wiz107SR: not found by configuration tool after firmware upgrade
RE: Problem with Wiz107SR: not found by configuration tool after firmware upgrade
Hi. B.Francois
* This process performs the following: [quote] + Erase the configuration data flash memory + Re-enter the MAC address + Device recovery to factory default settings [/quote]If your problem caused by configuration data broken, you may be restored WIZ107SR device by following steps with WIZ107SR interface board (EVB). But application data damaged during firmware update, user can not recovered. In this case, please request RMA to your dealer or our branch.
WizMACTool_v20151127.zip (7.1 MB)
by BFrancois ·
Hi Hkjung and thanks for the quick answer.
It seems that all the procedure operates as expected (no error nor log file). Despite of this, the configuration tool is not able to detect the Wiz107sr module.
Is it possible that by any manner, the W7100A iMCU firmware has been “damaged” ? Is it possible to re-flash it ? Regarding to the indication I found on the web, I am pretty sure that it is possible, but, do you provide the “factory firmware” in a binary format in order to do it ?
Is the RMA request the only solution to solve this problem ?
Best regards,
B.Francois
B.Francois, we are sorry to your problem.
Please tell us your hardware revision (printed on the WIZ107SR board) and firmware version information.
Tell you the truth, you can re-program the device MCU using full-firmware binary. But we cannot provide full-firmware binary to customers because it’s our product management policy.
Please request RMA to your dealer or our branch.
by BFrancois ·
Unfortunately, I am not currently at office. I will provide you the hardware revision as soon as possible.
Thanks for the update regarding to your policy, I was expecting this answer.
