Wiznet 107sr connected message
RE: Wiznet 107sr connected message
by djdjdjole ·
Thank you for swift reply. Didn’t know for that debug behavior. I will try.
Still no “DISCONNECTED” message, which sounds unusual to me, since there
exists “CONNECTED” message.
Regards
by djdjdjole ·
But what happened if 107SR is in server mode. Serial channel will report client connection, and not report
disconnection (if client side decides to do so). Of course, this could be solved on application level protocol -ie
client informs server (107SR) that it intend to disconnect.
Thanks
by kkdevara ·
Hi, i am working with WIZ107SR serial to Ethernet module; the module has been configured as TCP/IP client and settings for serial port has been configured with 9600 baud rate. The problem is the data from serial to Ethernet is being transmitted with the following settings (serial data to Ethernet packet formation)
but i need the data to come as ethernet packet not like a serial data on other side.
Could any one help, how do i send the entire data should arrival on TCP/IP server side.
by jameskim ·
If you use “Time” option, you may be able to send serial data to ethernet part as one packet.
The value in “Time” option field depends on your status, but 100(ms) works well in most cases.
