Wiznet107sr
RE: Wiznet107sr
Hello ravisankar.
These problem does not reported you mentioned.
Please tell us the WIZ107SR module revision (you can find PCB slikscreen on pads) and firmware version (config-tool).
Generally, the case of these issues caused by electrical problems.
we recommand to try to seperately test the WIZ107SR module only. (includes aging test)
The following system configurations, e.g.,
Devices to be controlled ----- [MCU] – serial – [WIZ107SR] == ethernet == TCP or UDP terminal
==>> [Debugging Terminal] – serial – [WIZ107SR] == ethernet == TCP or UDP terminal
If the WIZ107SR module reset does not occurred when test the module only, please check the configuration of the whole system. if not, (the module is still frequently reset) electric shock or damage is suspected and please request an RMA to your dealer.
RE: Wiznet107sr
by ravisankar ·
Hi Hkjung,
–Ravisankar
RE: Wiznet107sr
Hi. Ravisankar.
This is difficult situation to understand.
Could you please attach your schematic on this post?
I would like to receive as much information as possible about the problem.
Regards,
Eric.
