Setting Search Identification Code on a WIZ107SR
RE: Setting Search Identification Code on a WIZ107SR
Hi.
I think, try to packet capture and analysis using Wireshark program is good for you.
What is the difference between the two cases captured packets -your config tool and WIZ107SR config tool- is there?
by rhegner ·
It works now! The problem was not with the SP setting itself, but with the PD setting.
I sent PD0 instead of PD00 which apparently messed up the rest of the string…
