Search and settings
RE: Search and settings
Hi TizioM,
The configuration setting function of W7500P-S2E (WIZ750SR) also operates based on UDP broadcast like search function. Therefore, if the PC and W7500P-S2E devices are physically connected, the setting function will work even if they are configured with different subnets.
Regards,
Eric
RE: RE: Search and settings
by TizioM ·
Thank you Eric,
is there a document describing the discovery and parameter setting protocol of the W7500P-S2E?
I guess it is equivament to WIZ107SR/WIZ108SR…
I found a guide that applies to a different kind of wiznet S2E devices, I need something similar for the W7500P-S2E.
Thanks!
by TizioM ·
I just found the WIZ750SR Command manual (link below). I think it can be usefule, but I see the firmware update commands are not described. Since we have to load a custom firmware automatically, I need to be able to update firmware from my software. Is there any documentation of the ethernet protocol to update the firmware? Thanks!
http://wizwiki.net/wiki/doku.php?id=products:wiz750sr:commandmanual:start
