Setting of country code
RE: Setting of country code
by ssekim ·
Hello nils333
: Set System Restart
: This command saves configured data to flash. After this command is processed, configured data is kept even if rebooting.
You need to issue the below commands.
<ORnvram_set CountryCode KR && nvram_set CountryRegion 0 && nvram_set CountryRegionABand 0>
BTW, there was a mistake in previous my email.
by nils333 ·
unfortunately you advice does not help to save the Country code permanentely.
I have checked the following:
first action: set the country code as advised, followed by and commands
Result: The setting takes effect during run time, but is reset after power up
second action: set the country code as advised via serial command, followed by save action in web browser
Result: The setting takes effect even during a new power up.
It seems, that the country code command blocks any further commands issued via the serial interface, as the serial channel doesn’t react anymore after this command.
Have you got a workaroud for this problem ?
by ssekim ·
Hello Nils333
You had better issue the commands step by step.
Please issue the commands as below.
<ORnvram_set CountryCode KR>
<ORnvram_set CountryRegion 0>
<ORnvram_set CountryRegionABand 0>
<ORnvram_write write>
Now, maybe you can see the changed country-code in web-page.
Even after rebooting, you can see the changed country-code in web-page.
Regards, Steve
by nils333 ·
Hello Steve,
now everything works fine,
