Info regarding use of IRQ
RE: Info regarding use of IRQ
by somnatic ·
Hi midnightcow
I understand that data must not be sent or received in the interrupt handler. I do not want/need to do this.
In my program main loop, I have the tcp_loopback part which continuously performs SPI transfers. What I meant was not to require these transfers until really something has changed. Can this be achieved with the IRQ signal line? So can I say that if a transfer needs to be performed, the IRQ line will inform me, I will set a flag and then (some time shortly after in my main loop) I will initiate the SPI transfer? Or does the IRQ line only signal specific events and I will need to use polling in any case.
by somnatic ·
Do you plan on adding this feature to the W5500 driver?
fyi: I made a Altium library (schematic + footprint + 3D) for the W5500, after our internal review I can send it you if you want to have it (plus some screenshots how it looks so you can review it as well).
by somnatic ·
Hi
I attached the Altium library as promised. Use at own risk.
w5500-altium.zip (65.2 KB)
by somnatic ·
I could only attach 3 files, therefore added 3D view here
