Configuration of WAN port with seriel Interface failed
RE: Configuration of WAN port with seriel Interface failed
by kaizen ·
Hi
I did test about this issue. But I don’t find your problem.
This is my test environment. Can you check what is different you and me?
I connect LAN cable to WIZ610wi’s LAN port. And then I return
response when I issue the AT command.Is it right test environment for finding your problem?
And by the way, I used version 1.2.5(20130902) of WIZ610wi.
Thanks
by fossi15 ·
the problem for me is if i use command . It seems, that the Module did not see this command. I think so, because the Module remains in the actual state and did not response with
. And i am waiting for more than 1 minute. Switching from DHCP client to static IP with command is working also fine for me…Best regards,
Norbert
by kaizen ·
Hi
We saw this problem. So we will modify this problem to next firmware version.
But we need some time for fixing this problem.
Best Regards
by fossi15 ·
Hello kaizen,
thank you for your answer! So i will wait for new release of Firmware and meanwhile i will use version 1.2.4.
Thanks for your support!
By, Norbert
