W5500 layout
RE: W5500 layout
by wiznetmuseum ·
which is capacitor and resistor?
i can not distinguish on your brd file.
check the reference schematic of WIZnet’s WiKi
wizwiki.net/wiki/doku.php?id=pro … fschematic
RE: W5500 layout
by Monkeh ·
[quote=“herosmirr”]check the reference schematic of WIZnet’s WiKi
wizwiki.net/wiki/doku.php?id=pro … fschematic[/quote]
I’ve followed the reference schematic… I’m asking for layout advice.
RE: W5500 layout
by Monkeh ·
[quote=“herosmirr”]which is capacitor and resistor?
i can not distinguish on your brd file.[/quote]
It should be fairly clear from the very schematic you linked to… The silkscreen is turned off as I haven’t cleaned it up yet.
RE: W5500 layout
by wiznetmuseum ·
in your brd, arrow of orange color is pin1 of W5500. right?
could you explain what is the pin (box of orange color)?
we recommend designed 4-layers PCB.
but if you must make 2 layer PCB, i think that “the top plane around the pairs is 3V3A” is not good.
make top plane have ground too, like bottom.
RE: W5500 layout
by Monkeh ·
[quote=“herosmirr”]in your brd, arrow of orange color is pin1 of W5500. right?
could you explain what is the pin (box of orange color)?[/quote]
Yes. That’s the RX centertap.
Not an option, cannot make 4 layer boards with the software to hand.
[quote]but if you must make 2 layer PCB, i think that “the top plane around the pairs is 3V3A” is not good.
make it ground plane, too.[/quote]
All right, that’s doable.
Any other comments? Cheers.
RE: W5500 layout
by Editor1979 ·
I am looking for a good layout for this entire chip. Resistor, capacitor, and ethernet port values and the best placement on a dual-layer board. I am using a SI-50170 Ethernet port with LEDs. Any help would be greatly appreciated. I’d hate to make 1000 boards with this chip just to find I screwed something up.
