W5100 Listen issue
RE: W5100 Listen issue
Hi, Omer.
I want to know your code.
Please, post code.
How to set mode register, command and etc.
And I recommend to use reference code at WIZnet.
Best regards.
by Omer ·
I have attached the code files.
Please review them and let me know what I am missing.
I have done the following configurations:
Thanks!!!
wiznet_tcp.c (10.8 KB)
wiznet.h (11.3 KB)
wiznet.c (43.2 KB)
Hi, Omer.
I think your code is correct.
So, I want to know your main functions.
And I found strange code.
uint8_t listen(SOCKET s) { uint8_t ucharStatus; ucharStatus = getSn_SR(0); if (ucharStatus == SOCK_INIT) { write_wiznet_reg(Sn_CR(s),Sn_CR_LISTEN); /* wait to process the command... */ while( read_wiznet_reg(Sn_CR(s)) ); /* ------- */ ucharStatus = getSn_SR(0); if(ucharStatus == SOCK_LISTEN) { ucharStatus = 0; } else { close(s); ucharStatus = 1; } } else { close(s); ucharStatus = 1; } return ucharStatus; }You use socket number together ‘0’ and ‘s’.
So, please check whether it causes problem.
Best regards.
by Omer ·
I am calling the below function from main:
uint32_t initWiznet(void)
//unsigned char MAC_ADDR[6];
uint8_t status = 0x01;
/* Power the wiznet chip /
GPIO_PinOutSet (gpioPortC, 1);
Delay_ms(1);
/ Reset the wiznet chip */
ASSERT_WIZNET_RESET();
Delay_ms(1);
init_usart0_for_wiznet();
DEASSERT_WIZNET_RESET();
setRTR(6000); /* Retry time = 600 ms*/
Delay_ms(1);
setRCR(3); /* Retry count = 3 /
Delay_ms(1);
//setIMR(0x00); / Interrupt mask */
setGAR(); /* Gateway IP address /
Delay_ms(1);
setSUBR(); / Subnet mask /
Delay_ms(1);
setSHAR(); / MAC address /
Delay_ms(1);
setSIPR(); / Source IP address */
Delay_ms(1);
SysInit(0x55, 0x55); /* TX = 8kB, RX = 8 kB /
Delay_ms(1);
setIMR(IR_SOCK(0)); / Enable the socket 0 interrupt */
Delay_ms(1);
/* Configure the EFM32 for external interrupt from Wiznet chip */
NVIC_ClearPendingIRQ(GPIO_ODD_IRQn);
NVIC_EnableIRQ(GPIO_ODD_IRQn);
/* Configure PE13 as input /
GPIO_PinModeSet(gpioPortE, 13, gpioModeInput, 1);
/ Set falling edge interrupt */
GPIO_IntConfig(gpioPortE, 13, false, true, true);
write_wiznet_reg(Sn_IR(0), 0xff);
/* Open the socket for server mode /
temp = 1;
/ The below code is for testing purpose only
while( temp)
socket(0, Sn_MR_TCP, 80, 0x00);
temp = getSn_SR(0);
temp = listen(0);
/ Refer to GPIO_ODD_IRQHandler() for further packet processing
return status;
I am trying to connect to socket 0.
by Omer ·
If my code looks Ok, then how can I debug this issues?
Do I need to check something on my desktop side?
If yes then how?
Are there any tools which can help in debugging this issues?
Hi, Omer.
I wonder one point.
If your MCU is so fast, listen command could be done before SOCK_INIT status changed.
SOCK_CLOSED ------changing -------> SOCK_INIT
(listen command here)
So, I recommend to use case(1) or debug with changing return value(2).
switch(getSn_SR(s)) // check SOCKET status { // ------------ case SOCK_ESTABLISHED: // ESTABLISHED? if(getSn_IR(s) & Sn_IR_CON) // check Sn_IR_CON bit { printf("%d : Connect OK\r\n",s); setSn_IR(s,Sn_IR_CON); // clear Sn_IR_CON } if((len=getSn_RX_RSR(s)) > 0) // check the size of received data { len = recv(s,buf,len); // recv if(len !=send(s,buf,len)) // send { printf("%d : Send Fail.len=%d\r\n",s,len); } } break; // --------------- case SOCK_CLOSE_WAIT: // PASSIVE CLOSED disconnect(s); // disconnect break; // -------------- case SOCK_CLOSED: // CLOSED close(s); // close the SOCKET socket(s,Sn_MR_TCP,port,mode); // open the SOCKET break; // ------------------------------ case SOCK_INIT: // The SOCKET opened with TCP mode listen(s); // listen to any connection request from "TCP CLIENT" printf("%d : LOOPBACK_TCPS(%d) Started.\r\n",s,port); break; default: break; }i.e. check status is SOCK_INIT then command listen.
Try and then reply again please.
Best regards.
by Omer ·
Thanks for your replies.
The issues did seem to be with the delay.
I added delay in the wiznet read function and made it same like the wiznet write function.
The issue is resolved now.
Thanks once again for your help!
by Leytronix ·
Hi Omer,
At the moment I am running into exactly the same issue with the W5100. I understand you solved it with a delay in the read function? I do not understand where that is since the W5100 first has to go into LISTEN mode before anything can be read…
Can you explain that?
Thanks,
Tjerk
RE: RE: W5100 Listen issue
In the example above, a delay of 10ms was added after the chip reset.
