Wiffi210 connection & disconnection (urgent)
RE: Wiffi210 connection & disconnection (urgent)
by hobbex ·
here is my settings (at&v)
by ssekim ·
Hello hobbex
You can’t issue at-commands in data-mode.
If you want to disconnect it or issue additional command, WizFi210 should be transited into using “+++”.
Steve
by hobbex ·
Thanks Steve,
So, what about my Question#2 regarding the adhoc-connection procedure?
by ssekim ·
Here is my test scenario.
configure WizFi210 as ad-hoc mode(ssid : dddddd)
AT+NSET=192.168.12.254,255.255.255.0,192.168.12.1
at+wd
at+wa=dddddd (just test ssid)
configure PC as ad-hoc mode(ssid : dddddd)
In this step, I used with static ip.
Then the ping-test worked well.
How about test it again with another wireless utility(not zero configuration).
I guess the problem is related with windows-wifi-configuration-program(zero configuration).
Steve
