[From QnA]WIZ811MJ module with Arduino
IO Modules
IO Modules
RE: [From QnA]WIZ811MJ module with Arduino
by wiznetmuseum ·
Dear customer,
Thanks for your interest in wiznet.
There is a W5100chip in Arduino Ethernet Shield R3.
Arduino Ethernet Shield R3 is compatible with Arduino MEGA.
Arduino Ethernet Shield R3 schematic is as below.
arduino.cc/en/uploads/Main/ardui … ematic.pdf
Why is you using the wiz811mj?
Thanks,
Wiznet
by wiznetmuseum ·
Thanks for your fast reply!
I’m not using your wiz811mj module, but I found it more compact to use on my boards.
So if it’s work exactly as the Arduino Ethernet shield, I can use it instead of the Arduino shield!
thanks!
Massimiliano
