[From QnA]Unable to connect to my wiz811MJ module
IO Modules
IO Modules
RE: [From QnA]Unable to connect to my wiz811MJ module
by wiznetmuseum ·
Thanks for being interested in our WIZ811MJ.
Please follow the below suggestion to solve your problems.
Please check whether the MAGJACK LinkLED (Green) and ActLED (Yellow) is ON or not.
If you are doing test with LAN, please check whether your network parameter is correct or not.
For example the IP, GW,SUBNET MASK. Are your PC and WIZ device in the same subnet?
Best Regards.
