[From QnA] WIZ108SR HW rev1.1 and FW v2.20 HW_TRIG Bug?
RE: [From QnA] WIZ108SR HW rev1.1 and FW v2.20 HW_TRIG Bug?
by jameskim ·
Dear customer,
Currently, Do you use wiz108sr EVB?
If yes, Try to test again without Wiz108sr EVB.
Because if you use wiz108sr EVB, H/W trig pin will operate by switch of EVB.
And when power off, the default value H/W trig is high.
Thanks,
WIZnet
by jameskim ·
Thank you for your reply.
I started with EVB, but now I am using it directly and looking at the output of the HW_TRIG pin directly. Once connection is established the HW_TRIG goes low. However, if you unplug the eithernet cable which should close the connection, the HW_TRIG stays low it does not recognize the loss of connection.
by jameskim ·
Dear customer,
When wiz108sr started with EVB, HW_TRIG pin value is setting up by switch value of EVB.
Therefore you should use without EVB(Serial included) for correct measure of HW_TRIG pin value.
thanks,
WIznet
