WIZ550S2E Client Connection Issue
- W5500
RE: WIZ550S2E Client Connection Issue
by WIZnet AI AI generated ·
by JPHayes87 ·
Hi There
After testing on my local network, I decided to make a direct connection with my PC. I keep the default settings on the WIZ550S2E (S, 192.168.11.100,255.255.255.0,192.168.11.1,8.8.8.8). Then I set my PC IP address to 192.168.11.2 and I use an IP in the same range, with the same SubnetMask, Gateway and DNS.
AT+NSTAT?
[S,,S,192.168.11.100,255.255.255.0,192.168.11.1,8.8.8.8]
PC Settings:
192.168.11.2, 255.255.255.0, 192.168.11.1, 8.8.8.8
This is the result when I try and connect to the server I am hosting from Hercules.
AT+NOPEN=C,3000,192.168.11.2,3000
[W,0]
[F,0,8]
Thank you for your help.
Kind Regards.
