Porting ioLibrary_Driver to PIC24 using CCS PCD compiler
RE: Porting ioLibrary_Driver to PIC24 using CCS PCD compiler
by WIZnet AI AI generated ·
RE: RE: Porting ioLibrary_Driver to PIC24 using CCS PCD compiler
by allenhuffman ·
Hello, robot. I have a question about #5. The original headers contain prototypes that will not build on the CCS PCD compiler. I had to change those items in wiznet_conf.h and wiznet_conf.c, like this:
And the prototypes in wiznet_conf.h the same way, after adding the typedefs
Do you have a different way to approach this that would make rebasing with newer code easier?
by Aimee0 WIZnet ·
Hello, we recommend Port Layer Separation, as it provides the cleanest and most maintainable solution for long-term development.
Port Layer Separation (Recommended)
port_ccs.h/.cfiles to define CCS-specific typedefs and wrapper functions.Ex)
Macro/Casting Adapters
Ex)
Patch Branch Strategy
by allenhuffman ·
Thank you, Aimee0. At the time of my post, I was unaware of this method. In an earlier project we modified the library and I was doing the same.
I have now created wrapper functions. I began using the CCS compiler, but it was having problems with the HTTPServer example code. To make things easier for that, I switched to trying the MPLAB compiler. That made the process easier for both the I/O library and things like HTTP, SNMP, etc.
For any others doing this ... my wrapper basically looked like this (CCS code commented out, MPLAB code being used. I was never able to get everything running with CCS before I switched.)
Does Wiznet provide any stub file that has a similar wrapper? That would have been a very useful starting point.
This greatly simplified the process. Now we can just call the WiznetWrapper_init() and then start using it. Thank you.
