Using W5500 with PIC18F and MPLABX XC8 Compiler
RE: Using W5500 with PIC18F and MPLABX XC8 Compiler
What does it exactly mean? What is the difference in relation to W5500 implementation between PIC18F67J60 and PIC18F46K22?
RE: RE: Using W5500 with PIC18F and MPLABX XC8 Compiler
by andig ·
Hi Eugeny,
The PIC18F67J60 is a combination of MCU and PHY. It would be equivalent to PIC18F46K22 + ENC24J60 In both the cases the TCP/IP stack is in software unlike W5500 where it in hardware.
Microchip supported the W5200 way back in 2013 then they removed it from their stack.
Ok, so we are clear about differences, but what
Actually means? You can not compile? Did you do any troubleshooting what is wrong?
by andig ·
Yes lot of compile errors and seems my lack of knowledge on the Wiznet W5500. So I am looking forward to some running code examples that work with a PIC
by andig ·
Anybody with a working source code of W5500 with a PIC microcontroller (18F/24F/dsPIC) that can be run on MPLABX ??
by SVmetal ·
Hi, i am new with wiznet. I want use pic18F27k42 with w5500, have anybody some example how set wizchip_conf.c and some example code to test modul w5500? MPLAB, XC8… Thanks
