W5100 not supporting communication via switch.
RE: W5100 not supporting communication via switch.
by lawrence WIZnet ·
Hello, Rana_Uzair
Could I ask some network setting?
Are they same Switch between Uno to Switch and Due to Switch?
And Do you only connect Shield to PC via Switch? no other network like internet?
What about shield ip? do you fix them or use dhcp?
And What kind of communication do you use like UDP, TCP… ?
Sorry, lots of question… for me it is so strange too.
RE: RE: W5100 not supporting communication via switch.
by Rana Uzair ·
1- No, the switch is not same. Both Uno and Due are on separate separate switches.
2- If I attach shield to PC or an Access Point via POE, in both these cases the shield works. The shield+Due only do not work with a switch.
3- The shild’s IP for all are fixed, with different MAC addresses.
4- TCP and UDP both, basically a web server.
Alright thanks for your checking.
One thing could I know more about switch specific name ?
Because some how W5x00 affected by some switches like Cisco.
(And what if you change Uno and Due, then we can find what happens the problem.)
And If Link LED is flashing, could you fix the speed 100 or 10 from switch configuration tool ?
by Rana Uzair ·
The switch is usual hub type unmanaged 5 port.
Hence the speed cannot be specified.
The packages have been sealed so the shielda cannot be swaped in between uno and due.
Could I know which model they are and which company they came from?
I could not get the point, it is packages. It does not matter it is package or not.
case1) package a (uno+shield) <–> switch a <–> pc : work?
case2) package b (due+shield) <–> switch a <–> pc : work?
case3) package a (uno+shield) <–> switch b <–> pc : work?
case4) package b (due+shield) <–> switch b <–> pc : work?
I just want to check the switch is working well with W5100.
What are the MAC address, IP address, IP mask and gateway settings for both W5100 devices?
