W5500 and matter protocol are not compatible?
IO Modules
- W5500
- Arduino IDE
IO Modules
RE: W5500 and matter protocol are not compatible?
by WIZnet AI AI generated ·
by Hannah ·
I’m not a Matter expert, so my answer may be limited. However, based on the AI’s suggestions, I recommend checking the following areas that often cause issues:
Confirming these two points first should help narrow down the root cause.
